Eagle 1
- Messages
- 99
- Reaction score
- 3
Has anyone every tried to start their Yamaha 150 HP engine (or any Yamaha outboard engine, for that matter) using the Emergency Starter Rope (while having a dead battery or very low battery because one failed to bring a portable battery jump starter along with them)?
On 4-11-2014, I will finally take possession of my new 2014 Bennington 2375 GCW with a 150 HP Yamaha engine and I have purchased a "PEAK PERFORMANCE 900 Peak Amp Jump-Starter" to take onboard with me just in case I ever in the distant future inadvertently run down my battery while listening to music while sitting quietly in a cove on Kerr Lake, NC.
I don't expect this will ever really happen (given the length of time that a well-charged battery takes to run down by just listing to music, etc., plus I'll never stay in one cove with the engine off for that long anyway, plus I could run the music straight from the battery jump-starter anyway). Still, I am the kind of person that likes to have an idea of what to do in a worst-case-scenario. So that's why I bought the battery jump-starter mentioned above.
However, on page 6 of the jump-starter manual, it says that when jump starting a vehicle, connect the red (+) cable to the red (+) terminal on the battery, but do NOT connect the black (-) cable to the black (-) terminal on the battery. (I've always connected the black cable to the black terminal when jumping car batteries and never had a problem, even when the car is supposedly negatively grounded. But regardless, if I am correct, the pontoon boat is NOT negatively grounded and so I hope I could connect the black cable to the black battery terminal without any problems.)
So, the first question is "Has anyone safely jump started their own boat's engine using a portable jump-starter and connected the black cable to the black battery terminal, despite the pamphlet's warning against this?"
Also, while reading the Yamaha engine manual about jump-starting the battery (and the manual does to directly address this question, for obvious reasons) I came across page 74 where it said "Emergency Starting Engine" and for number 6, it said, "Insert the knotted end of the emergency starter rope into the notch in the flywheel rotor and wind the rope several times around the flywheel........."
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-95_6E5-101496-Current_1792.pdf
I didn't even know that it was possible to start my outboard engine in a dead-battery-emergency like I would ordinarily start a an older lawnmower engine. So the second question is "Has anyone every had to start their engine this way?" And the third question is, "Where is the Emergency Starter Rope stored...under the removable cowling with all the accompanying heat of the engine?"
