Here is what the Propgods emailed me about my current prop setup:
Well, that prop is slipping badly.
You could take it to a prop shop and have them add a little cup to it. It might help.
Two props that I'd be curious on.
The Revolution 4, is a good all around 4 blade. Normally 4 blades are slower on top end, however, if your prop is slipping a lot, and you need more traction, it may actually outrun the 3 blade
And the 3 blade Mercury Enertia. Its smaller diameter then your current prop, but it normally hooks up strong, and its a very fast prop.
If we were setting this boat up from scratch, I'd be leaning toward the Enertia.
Both props are $499 and require a $35 hub kit to make it fit a volvo.
If you get one and it doens't perform well, you can swap out for and different style or pitch for $35 plus shipping.
