BigKahuna
I'm sure you can "Macgyver" something. Hooks, bungee cords, straps, etc.
Wow. You actually tested two different pumps. That's amazing. My method doesn't allow me to check PSI, perhaps I should upgrade my pump because I know I've used it a little under inflated before.I just finished testing the Outdoor Master Shark High Pressure vs WOW Watersports 3psi pumps on my Big Mabel. The OMS pump took 5 minutes, the Wow took 4, the OMS was about 1.5psi while the wow was closer to 1 - both acceptable. The OMS was $170, the WOW was $70. But, the OMS turned off automatically when done, will work with my SUP, and was able to fill two tubes without getting hot. The WOW was very warm and also heated up the 12V cord after just 1, there was very little heat coming from the OMS. Took about 7 minutes to deflate using the pump AND roll it back up on both units. It's a bit pricey, but the OMS pump so far seems like it's worth the premium, keeping the WOW as a backup.
These were rock solid when full with both pumps. No need for a manual pump to finish off. But the Outdoor Master Shark High Pressure allowed me to start the process and walk away. Unishot's post is correct - best to clip direct to the battery. I found a heavy duty "car" receptacle and am going to give that a go (kids, electric, positive / negative - I want to avoid any "errors").Wow. You actually tested two different pumps. That's amazing. My method doesn't allow me to check PSI, perhaps I should upgrade my pump because I know I've used it a little under inflated before.
