We currently have a lift that uses bunks under each toon. We are moving to a new place and our lift company wants to convert the lift that is there to a "center lift". The toons will not be supported at all and it will use a catamaran style of two supports under the base of the boat - essentially the toons will hang and the support is in between each toon and using the floor to lift.....thoughts?
