Modifying our boarding ladder....
Had my L knee replaced last May. My advice be sure to do all the PT....PT is very important to get back your range of motion. Nice to finally be pain-free in that knee. Good Luck.
Yup everybody I have talked to has stressed to really go all out in PT so I'll get the range of motion back and recover quicker! Not too crazy about taking all of that narcotic pain relief!
One more rung will be that much more added leverage on that hinge. Hopefully it can handle it
Thx for the thought! Yeah I discussed that with the welder. He says it can handle it! We'll see!
Why not just install the new lillypad ladder - way easier.
Yes I considered it! Like I said earlier I've seen it on another members boat and it looks fantastic and well built! I just need 1 fabricated rung from a local welder here and will be all set! It will have the same amount of steps in the water as the Lillipad ladder but about $1100 less expensive!
Okay couple quick updates....Had knee replacement surgery on February 26th. Went really well or so I thought.......My surgeon installed a Q ball pain pump by catheter directly in my knee and I didn't feel a thing for 3 days! Heaven! But when that pain pump started to wear out running out of medicine......I couldn't take those Hydrocodones fast enough! Long story short I was in pain for the next 5 days and that was it! Started PT and breezed right through even driving myself to PT at week 3. Don't get me wrong it was still really stiff, numb and sore but once the pain goes away it makes it a lot easier! I was able to play pickleball at 9 weeks on May 1st! Update 2....Having that welder add another rung/step to our boarding ladder makes a world of difference especially with a new knee! We now have 6 total steps to board. Money well spent! (Thx to forum member Nautical for installing/riveting the new retrieval strap! Update #3......Forum member potomacbassin has been trying to get me to remove a sacrificial anode that was installed directly in front of my Simrad transducer. Removing it would hopefully produce "clean water" so my Simrad wouldn't drop reading the depth at speed. Well we were out yesterday and removing the anode didn't work. We still lost the depth gauge at around 18 mph. Any other ideas?!?
Amazing isn’t it. Panthergirl had her hip replaced (robot assisted) May 12th in am. Walking (barely) by 3:30. 1st week with walker, week 2-3 with cane, week 4 unassisted and out walking around nurseries (plant! :p).
I read, and she said, walking in was pain level 10, walking out a 3 (exclusive of the “surgery pains”). Technology is crazy.
The main thing is she isn't in pain anymore! It's really amazing what they can do! Did she have to go through any PT? Did she have an anterior procedure?!? I had an anterior hip procedure done in 2021. I was pretty much back to normal in 4 weeks! This knee was a different story......Glad she is running around!!!
I solved my similar transducer problem my moving the unit to the bottom of the mount (original is my Benny, lowered is another Benny).
When you can, please post pictures on that new ladder setup!!!
Did moving your transducer make you NOT lose your depth reading at speed?!? My transducer location is very similar to yours but I lose my reading at about 18mph every time! Yes I will post pics of my extra ladder step/rung next time we go out! That 1 step makes it so much easier to board because it makes it a little deeper in the water!
Yes, prior to lowering the Transducer 15-20 was my max. Now I can hit 30+, 45 in the attached picture! I found a more recent picture of my Benny, seems I lowered it further than the prior picture - mounting the plate as low as possible with the transducer well below the mount plate.
Thx! I'll keep moving it til I get results!
Before doing any more mods to it, find out if it's capable of that in the first place. The cheaper ones aren't. My first Benny had an upgraded system that read at any speed, even giving a terrain map too. The Manitou only worked when still or maybe at idle speed but nothing more. This latest boat it seems to work at speed. Some unit are simply not capable of it.
Before going doing any more mods to it, find out if it's capable of that in the first place. The cheaper ones aren't. My first Benny had an upgraded system that read at any speed, even giving a terrain map too. The Manitou only worked when still or maybe at idle speed but nothing more. This latest boat it seems to work at speed. Some unit are simply not capable of it.
It's right there below the ladder so I can easily move it around so no big deal! Our previous Bennington read depth at all speeds. It wasn't a Simrad. Just a regular digital depth gauge!
Here you go Laurence. The ladder and Simrad transducer position.....One extra step makes a big difference for me! I can probably move the transducer down a little more to see if it'll read at speed!PXL_20250617_143005024.MP.jpgPXL_20250617_142950570.MP.jpgPXL_20250617_142919519.MP.jpgPXL_20250617_143020079.MP.jpg
I know this is not likely to ever happen, but if you had an underwater camera pointed at the transducer while running it would probably show some turbulence that is creating an air pocket the transducer cannot beam or receive through. Gotta find some clean water so moving it around might end up being the ticket!
Good video, Aussie accent is a bonus.
Good video! I have done everything he is suggesting! I've had it flat with the bottom of the toon! I've tilted the transducer down a few degrees where the rear sits a bit below the toon! But I do have the keel that he mentioned pretty much directly in front of the transducer that could be causing interference! I'll check to see if I can move it to the left or to the right of that keel next time I go! Thx!
Transducer: All the post I have seen with the transducer working past 20mph were located at the bottom (same plane your's is), but the farthest to the outside as possible - seems that is your next step!
Ladder - that is awesome!
Thx! Just the plain old aluminum ladder with an extra rung! I'll try to move the transducer to the outside!
Simrad transducer update..........Moved the bracket holding the transducer as far down as I could. We were on the water yesterday so we had all day to test it! When we first started out I held my breath when we hit the 18 mph mark but it kept reading......until 26.8! First time it read the depth past 20 mph! But throughout the day it was pretty sporadic losing the reading at different speeds! One time we lost the reading about 22 mph then it picked up again for a while at 32/33 mph then lost it again! Pretty frustrating but we made progress!
