schmeg
- Messages
- 58
- Reaction score
- 0
Point I was making kinda goes hand in hand with Todds findings. His approach has to to with thrust output. No brainer there. Bigger motor, bigger prop, more thrust. Always works out to the advantage going
to bigger displacement motors. The point I was making is like aircraft, the more drag you induce on a boat, the more power it takes to overcome the drag. If more of your toon is in the water due to weight and
balance issues, the more power it will take to get it out of the water. I bet even though you are on plane with a heavy load, more of the toon is displacing water. When you get to a certain point in drag, the amount of thrust to
overcome the drag is exponential . I'm in the KC-135 tanker. It goes through similar issues for different reasons, but the theory can be applied in a similar fashion. If we enter "holding" with the airplane and assume a "holding speed"
which is slow, the airplane achieves a high AOA. Once we get to a fine line at a given AOA, it takes a lot more thrust just to maintain a given airspeed. If we momentarily "push it up" the airplane will go on the good side of
the lift over drag equation, and to fly the same profile requires much less throttle. In the plane case, it's not about a hull in the water, but it is about drag, similar to a boat. Long story short, your 115 "is what it is". Not much you can do
to make things better other than the right prop. What you can do is place heavier people on the stern lounge, and lighter people up front. Also when the boat is out of the water next time, there is a wax coating that seaplane flyers
use on there floats that will make the floats real slick in the water. They apply it once a season. I'll find out the name of it today when I go to work. My buddy uses it on his runabout and gets 4-5 mph more out of it. You would need
to have clean toons to apply it, and not have it sitting on bunks. I'll check back with the name of the stuff.
