Hi guys, I just took delivery of my new to me 2019 22-SPS-200. That's the model number on the placard below the throttle. It has a Yamaha 200 and I believe it's a swing back which has a lounge area in the back with a back rest that swings aft to form a bench seat facing forward.
So to my questions:
So to my questions:
- The boat is on a lift with a cradle. The boat house has a dock that's U shaped allowing me to walk around both sides and the front. It appears it's going to be very difficult to work on the engine with the boat in the boat house. The engine is so far back that it's difficult to even reach the aft cowling latch. So I was thinking to remove the engine cowling I could back the boat into the boat house ensuring the cradle is deep enough to clear the prop. That way I could work on the engine from the dock. What do you guys do in similar circumstances.
- The engine has 40 hrs on it. It was previously operated in saltwater. It will probably never see saltwater again. I live on the Harris chain of lakes in central Florida. The engine had the 20 hr service done, I have the receipts and that was in Oct 2019. Anything I should do now that the engine will not see saltwater? I have seen some minor corrosion on some aluminum parts, mostly the bolts that connect the engine to the transom and other aluminum parts on the boat, like the steering wheel. Since it's been over 2 years since the 20 hr service I was going to change the oil and fuel water separator. Anything else you guys recommend.
- And speaking of the fuel water separator, I can't see a part number on the current separator. It's Yamaha branded but no part number.
- Does the boat have a blower to remove gas fumes? None of the switches on the panel are labeled as such.
- The engine manual recommends fuel additives. What do you guys use?
- Lastly, for the time being, what seat cleaner do I use? The seats are not of the vinyl type that I'm familiar with but rather a fabric or perhaps a canvas type. And what about the floor? It's a type of closely weaved material.
