You didn't say where you are at and temperature makes a lot of difference with trailer tires. I live in the southwest desert where we were over 125 degrees several days this summer. That makes some very hot pavement! You gotta have solid equipment to handle that safely.
Your boat prolly weighs in around 2700 - 2800 pounds so a single axle set up can do the job IF, and that's a big IF you have good tires and keep them up to pressure. Last time I shopped trailer tires the Goodyear Endurance tire was only trailer tire made in USA and they are very good tires. I have them on all three of my trailers, the boat, my toy hauler and a flat bed I have. In this heat nothing less will do.
I would recommend if you stay with a single axle boat trailer you overkill the tires by stepping up the class rating on your tires. If the trailer has load C tires move up to D rated and keep them blown up to pressure.
Your best bet, and safest, would be a double axle with brakes on at least one axle. My boat trailer has disc brakes and even though I tow with a diesel pickup truck I don't know it's back there when I stop.
As a side note my trailer has guide posts at rear of bunks and can be tricky to load in wind. I plan to put guide bunk boards along inside of pontoons and get rid of the posts this winter.
