Welcome to Club Bennington
Login Register
Electric Bimini reinforcement. C
Discussion in 'Do-It-Yourself Projects' started by Lake Gaston Bennington, Apr 17, 2017.
  1. Lake Gaston Bennington
    Lake Gaston Bennington Member
    18
    4
    I'm curious to know if anyone has reinforced there electric Bimini.?  Seems it'd be easy enough.  I haven't received my new boat yet however I ordered the electric Bimini as I have to cross under a low bridge regularly and it was a bit of a pain with my old Bennington's Bimini. I was on the fence about the electric Bimini but figured worse case, if it's unstable at higher speeds, how hard could it be to add the little support arms in the front.  Anyone know where to get all of the OEM Bennington materials?  The tubing, clips etc?  Anyone on here comment on there experience with the electric Bimini?  Thx folks.
    So psyched to get my RSB 23 with Yamaha 200 SPS tri with all the fixins
  2. SEMPERFI8387
    SEMPERFI8387 Moderator
    7,971
    2,271
    York, Pa
    You would have to go through the dealer for OEM parts.
  3. cwag911
    cwag911 Moderator
    5,088
    1,230
    You have to remember that the electric bimini isn't made by Bennington and I don't know if the frame is the same size as the railing.
  4. Lake Gaston Bennington
    18
    4
    I'd assume your correct however there are no OEM parts to reinforce the electric Bimini because it's not reinforced nor is there any option that I've seen to add reinforcements.  Therefore the better question would've been simply, has anyone on here reinforced there electric bimini and if so, how'd you do it?
    MikeB and cwag911 like this.
  5. Team Bennington
    Team Bennington Administrator Staff Member
    751
    263
    Ask your dealer to order a set of stern Bimini brackets that he can install for you to reinforce the electric top if you feel you need it.  Several dealers add this to electric biminis for rough bodies of water.  TB
    MikeB, BulldogsCadillac and adkboater like this.
  6. JBL
    JBL Well-Known Member
    119
    16
    Clayton NC
    I use a braided rope attached at each front corner and hook the other end of the rope to the rail in front of the driver and the port side in front of the gate. Gives stability to the top. I use spring hooks to attach to the railing.
    MikeB likes this.
  7. kt700
    kt700 Member
    5
    22
    Southeast Wisconsin
    We have electric bimini on our toon, we are in a smaller lake and it doesn't get too rough, but don't see the need for any additional supports. I think you will be happy with the top, easy, quick and smooth movements. Good luck!!
  8. Link
    Link Moderator
    4,583
    1,641
    Sacandaga Lake, NY
    Nice looking setup kt700, like how the Evinrude matches the boat
    kt700 and cwag911 like this.
  9. adkboater
    adkboater Well-Known Member
    810
    520
    Tylersport,Pa
    KT700...... that’s one sweet boat!
    kt700 likes this.
  10. kt700
    kt700 Member
    5
    22
    Southeast Wisconsin
    Thank you, our first pontoon and we love it!! Evinrude and Bennington have the matching colors all setup, between them. This is our first experience with an outboard as well, very quiet, fuel efficient and pushes that 25'er to just under 45mph, who needs to go faster than that.
  11. Fastoon
    Fastoon Active Member
    31
    7
    Lake Texoma
    I have dual PWR Arms and don’t see the need for support.
    On Texoma and gets pretty choppy...
    Originallly thought about using parts from my factory top to make support arms but so far it’s fine.
    MikeB likes this.
  12. MikeB
    MikeB Well-Known Member
    52
    47
    Spring Branch TX (Canyon Lake)
    I was thinking of dual PWR Arms as well. I spoke with the factory about which way to orient the front Bimini, either folding towards the bow or the stern. Which one did you go with?
  13. Fastoon
    31
    7
    Lake Texoma
    I mounted it folding to stern. In Radar up position it seems to look better and out of the way.
  14. Pittsburgh
    Pittsburgh Commodore
    1,457
    566
    Metro Pittsburgh
    Would like to see The Bennington Name more Pronounced on The Boat
    Surprised it doesn't stand out more
    [​IMG]
    On that Boat Gold Logo would be AMAZING :)
    cwag911 likes this.
  15. lakeliving
    lakeliving Well-Known Member
    6,631
    3,057
    Not sure yet
    Pittsburgh, Alicedream and cwag911 like this.
Share This Page
