kaydano
- Messages
- 4,287
- Reaction score
- 2,163
Whether you've had this problem, or not yet, remember to peek at your gas hoses next time you are out. You might be able to avoid the issue.
I ordered a external vent and a loger piece of hose from overtons and mounted it right next to the fuel fill, I had to drill a hole to mount it but it looks great and I have no more issues with fuel splash back.You may have fixed this by the simple fact that you ran a separate vent (and not so much the size of the hose).
What did you do to terminate your new vent? Just let the vent hose lay loose (or tied up) inside the boat? Or did you drill a hole in the side of your boat and run it through a plastic tube/grommet/flange thingy? Maybe you just stuffed it down the hole where the canister hose goes? Curious what you did...
There are several vent devices available. Some are more sanitary than others, though serve the same purpose. Yes, Ethanol is known to develop phase seperation, especially over an extended storage period. Basicly, Ethanol wicks or attracts moisture from the atmosphere, over time, the Hydrogen seperates and appears as water. Thus, phase seperation, part hydro-carbon, part water.I may be missing something, however it is obvious more fuel is going in than vent air is coming out. The spew occurs when air rushs out the filler neck and brings fuel with it..... So, either the vent line is under capacity or restricted. Modern EPA has something to do with the fuel cap and safety may mandate a restrictive vent design. Though, from a point of safety, spewing gas is not safe.
Perhaps an "enlarged vent line" from the tank To a "T" To a capped auxilary vent head, to be opened when fueling. The other leg of the "T" will create the original circuit. There should be less back pressure if the "T" is placed close to the tank. At that point the only restriction would be subject to capacity of the tank vent fitting.
With some amount of vent, fueling becomes similar to filling a bucket with the garden hose.
Thats a interesting solution Ccando and I was considering that very thing if I run into water issues in the fuel. I just hosed it up like my previous Tahoe boat which came that way from the factory and never had water issues but that being said I always put marine stabil in the tank every time I get gas, Not sure if it helps but so far so good.There are several vent devices available. Some are more sanitary than others, though serve the same purpose. Yes, Ethanol is known to develop phase seperation, especially over an extended storage period. Basicly, Ethanol wicks or attracts moisture from the atmosphere, over time, the Hydrogen seperates and appears as water. Thus, phase seperation, part hydro-carbon, part water.
An uncapped vent line is a clear, unrestricted path to the atmosphere. The boat, on the water, is exposed to a greater Dew Point than land based storage. Therefore, the risk of absorbtion increases when the boat is on the water.
The solution may include a seperate vent hose/vent that is opened when fueling and closed after fueling.
Well, now that you call me on it, I'd have to say it is semi-open, and not fully closed. From a practical matter though, it seems like a closed system to me.Kaydano, are you saying that the Bennington factory system is closed but Ken H's solution to fueling your Bennie makes it an open system?
Ken, Typically, best intentions are to fuel today and use the boat tomorrow. However, Murhy's law has proven best intentions don't always happen, as planned. Then, speaking of Murphy's law, from time to time fuel dock gas is KNOWN to contain water. Therefore, using Stabil is only prudent insurance. In fact some may say, not using Stabil or something similar, is Mal-Practice.Thats a interesting solution Ccando and I was considering that very thing if I run into water issues in the fuel. I just hosed it up like my previous Tahoe boat which came that way from the factory and never had water issues but that being said I always put marine stabil in the tank every time I get gas, Not sure if it helps but so far so good.
But it would be very easy to install a ball valve and switch over to fuel up and then close it off again.
Cheers
Ken
I have a center tank on my 2575. It will spits gas out when its full. I listen for the rush or higher pitch sound and shut off the flow and step back and watch it squirt. This is at the station, boat on trailer.So once again, does this problem still exist with the center tube fuel tank, or does it seem to be more the deck mounted?
Thanks, Derrick
We'll be in Detroit over Labor Day weekend! But normally we are in the Willamette River, in Portland.Where do you boat in central OR? I have mine up at Detroit Lake.
