ct0218
[SIZE=10pt]We are nearing the end of the comment period (Jan 28) for the EPA proposal to cut back on the amount of ethanol in fuel. The ethanol enrichment of 10%, which has many supporters for increasing the amount to 15%, has been nothing but a disaster. !0% is bad---changing to 15% is a whole lot worse! The use of corn and other grains to produce alcohol has raised food prices as well as the prices of many unrelated items. The alcohol enrichment has reduced your fuel mileage, and ruined the fuel system in older vehicles, all boats, and all small gas engines like lawn mowers, etc. Send an email using the link at the bottom of the page. This particular comment form was produced to help boaters by the National Marine Manufacturers Association (NMMA), and none of this has received much publicity by the media---surprise, surprise.[/SIZE]
[SIZE=11pt]Contact the EPA and Save our Boats
Submit comments to the EPA to end the Ethanol Mandate[/SIZE]
[SIZE=11pt]The Renewable Fuel Standard (RFS) is a failed government policy that endangers marine engines and the boating community. The EPA in response to our concerns is proposing to alter the RFS and reduce the amount of ethanol required to be blended into our fuel supply. But first, the EPA needs to receive public comments in support of this proposal.[/SIZE]
[SIZE=11pt]NMMA has provided a sample comment for you to submit- it is editable, which means you can input your own thoughts and experiences, or you can simply submit the prewritten comment.[/SIZE]
[SIZE=11pt]Please spend the next few minutes submitting your comments easily and effectively through the Take Action button below.[/SIZE]
[SIZE=11pt]The corn and ethanol lobbies are hard at work submitting comments to preserve the mandate. Don’t let them get the only say in this matter![/SIZE]
[SIZE=11pt]It's time to protect our boats, our marine engine and boaters. Submit your[/SIZE] [SIZE=11pt]comments today![/SIZE]
Link:
[SIZE=medium]http://capwiz.com/nmma/issues/alert/?alertid=63045576http://capwiz.com/nmma/issues/alert/?alertid=63045576[/SIZE]
Link:
