JSM
Anyone have a two tube 25" no performance upgrades with a 150HP? 2275 GCW. If so, what kind of performance are you getting?
Where ?I am starting a PADS Phobia class beginning next week
My guess is that your boat would be perfectly capable and safe to support much more HP than a 70HP but being a few years older Bennington was very conservative in stating maximum HP limits. Now with the trend towards more power they are upping the limits while still staying within the safe zoneSince you are rated for the 150, and your profile says you have a 70, i would imagine doubling your HP should give you a substantial performance increase!
Look through the props and power section to see if anyone has a similar setup.
Here is where i get troubled, i have a 20' with 2 25" tubes, it is an S series, but, mine is rated at 70hp max. Someone tell me how 2' longer tubes justifies twice the hp's? Am i missing something?
It's awful that a Q doesn't come with a waveshield as standard equipment.the GCW I had before this QCL was a twin 25" without any performance upgrades and a 150. it DID have a waveshield. Man that thing was fast! I clocked around 36mph... Now i'm lucky if I can get to 30 with the heavy QCL on ellipticals and no wave shield on a 150.
It probably has more to do with the extra weight in rear being offset by the extra weight in length. Could you imagine a 20 with a 350 hanging off the back. It would look like that video Carl posted in the hobby thread with the boat standing on its butt.It is curious. The 23 series is rated for a 250 and the 25 series can handle a 350
Beg to differ. The main factor for speed is all about planing vs displacement. It's not even about 2 tubes vs 3 tubes, although 3 tubes generally are going to plane up quicker. Generally. The ellipticals are fast (with strakes) since they have more planing surface than a round tube does. Any planing hull will take off once it planes up vs. a displacement hull. A displacement hull's speed is limited by it's length (odd but true) and no matter how much HP you throw at it, it won't go appreciably faster until you get it up on plane. So, that's the primary factor (planing vs displacement). Then come the weight/buoyancy/wetted surface factors, which I agree ARE factors, but much less so than planing vs displacement. You want a hull to plane up first, then the other factors come into play and are much more "granular" as far as impacts on speed.Center tube gives more buoyancy but adds weight and wetted surface (more drag).
Unless heavily loaded, a 2 tube boat is no slower than a 3 tube.
This is why the twin ellipticals is their fastest hull.
