Ptm Edge offer for a group buy.great deal if you've been looking for a mirror.
3dmac88
Many, Louisiana
I have the larger mirror and a 1/2 gallon Crown Black bag works perfect as a cover....
M Jay Farr
Smith Mountain Lake
Wanted to post a follow-up ref this mirror. The mirror and application are great. However, I have run into a problem whereupon I can not raise the mirror without the set screw damaging the bracket. It appears that the set screw is just a tad too long and does not fully allow for clearance. At this point, the unit will no longer screw into the base for a secure fit. I have sent a note to PTM Edge to learn what if any actions they will take to address/correct the problem. Keep you posted.
Unishot
See my earlier post. I had the same issue. Try loosening the two horizontal screws at the base of the arm. That may solve the problem, according to the rep at PTM.
Unishot
It’s not the two screws that secure the bracket to the rail, it is the two screws that are at the pivot point of the arm, by the hinge.
M Jay Farr
Smith Mountain Lake
Thanks, this was the same advice I received from Jason at PTM. He was most responsive. I will give this a go when I go back to the lake later in the month.
