Bill N
- Messages
- 1,827
- Reaction score
- 2,283
It might do that.....on the trailer.I had no idea this would top out at 85 mph.
Anxious for pics, sounds like a nice boat!
Pictures or it didn’t happen. Add some snoopy googles to the mix as well.Thinking I should buy a helmet and new life jacket lol.
Very sweet!Love love love my qx withe Mercury 400 V10. Really like the front bimini also.
I guess you're right. When you look at the center tube compared to the starboard tube they both look rounded and pretty much the same size. But when you look at the reflection in the water you can tell the center tube is significantly larger than the starboard tube.... What do you think?I think you're wrong. It looks like an elliptical to me?
Good eye. I didn't even think to look for a reflection!I guess you're right. When you look at the center tube compared to the starboard tube they both look rounded and pretty much the same size. But when you look at the reflection in the water you can tell the center tube is significantly larger than the starboard tube.... What do you think?
I have had my 25 foot QX with sport arch and midship bench seat with a Suzuki 350 twin prop for this season. It is a heavy boat and it tops out at 48 mph when raising the trim. It does handle the chop very smoothly and it is a gorgeous boat. I bought that engine, wanting to pull skiers, and there is still a bit of a lull despite the twin prop Suzuki being reputed as popping out of the hole. My only other criticism is the Bimini is not designed well in terms of the ease of operation.Hi folks! Well I drank the koolaid this weekend and decided to buy a used QX instead of the LX. I absolutely love the style of the boat. Will the QX owners chime in on their pros and cons of the boat? Thanks have a great day!
What didn’t you like about the Bimini? We will definitely be using it 99% of the timeI have had my 25 foot QX with sport arch and midship bench seat with a Suzuki 350 twin prop for this season. It is a heavy boat and it tops out at 48 mph when raising the trim. It does handle the chop very smoothly and it is a gorgeous boat. I bought that engine, wanting to pull skiers, and there is still a bit of a lull despite the twin prop Suzuki being reputed as popping out of the hole. My only other criticism is the Bimini is not designed well in terms of the ease of operation.
If you want to use the Bimini, you must first remove it from its boot or cover. The cover has cleats that hold the Bimini to the sport arch. You then must zipper the Bimini to the sport arch left and right, which is not easy. It’s usually a two person job getting the Bimini attached an open. When you are done, and folding up the Bimini, you cannot then go under power as the Bimini will fly backwards. If it is not put back in its boot or cover with a cover, then cleated to the sport arch. In order to put it in, it’s boot or cover. You must unzip it from its attachment to the sport arch. All in all a very cumbersome process.What didn’t you like about the Bimini? We will definitely be using it 99% of the time
Chap stick! Great ideaAmazon sells a zipper lube, others have used chap stick and on the snaps as well
