Jack M
On my RCW I had a cable that kept coming out of the back of the Garim . Do they still have that cover under the helm hiding the cables ?
The consoles on pontoon boats will often have a rats nest of wires dangling from their connections. This seems to meet the standards of the industry. For the moment I have 3 pontoons. All 3 came with a rats nest of wires that made it difficult to trace wires. While doing other modifications I cleaned up the wiring on both my new Bennington and the boat up north. I am now preparing to sell my old boat (with its rats nest of wiring) because it has been replaced by my new Bennington. I have had that old boat for 27 years. In that time I have not had a wiring or connector failure. The rats nest had the potential to effect serviceability but obviously not function. While redoing the console of my new Bennington I noted that the functional qualities of the wiring met a good standard. Even if I had not cleaned up the wiring on my new Bennington I would not worry about the boat giving good service for a long time.That wiring “nest” has been that way since at least 2012 when I bought my first Bennington. Don’t sweat the small stuff.
When you do pop some of the connections, throw some dielectric in them. I have a wonky stereo connection that I lose speakers sometimes. A jiggle and it’s good to go. I keep forgetting to bring the grease to fix it.
Good point. Slight corrosion has been my issue on 2 boats with the speaker issues.On another topic dielectric grease will improve corrosion resistance but not electrical conductivity.
I’m thinking since these wouldn’t typically sink due to water intrusion, they just put it on a switch for “as needed”. It’s also probably just a regular bilge pump, not a float switch pump which you would need for auto function.The grease is a good idea. I’m costing all electric connections with anticorrosive spray today. Then doing the ceramic coating. I just found out the bilge pump is not on auto all the time, that seems really dumb. Shouldn’t it be on a hot battery buss?
My switch has an on position, off positions, and auto position. I swear auto would simply run when there was water, I didn’t think my auto just ran all the time. However, after a year of not having the boat operational, and still another full month before I even get it back, it will be awhile before I can test that out.My Q had a dual switch on the control for "auto" or "Manual" for the bilge pump. But, I don't think it had a float so turning it on auto just turned it on. I'll have to take a look at the pump on the Q, and the switch and see how it's set up. I'm assuming it has no float and is just an on/off. It would have been great to get out this weekend, but after 2 years of avoiding covid it finally caught me last week. I spent the weekend in bed![]()
Right! I paid $260 during my service to have it direct wired from the battery with it's own power switch. Our monsoons can dump 10 to 20 gallons into my center toon quickly (even covered - hits the front deck and runs downs into the center tube hatch).The grease is a good idea. I’m costing all electric connections with anticorrosive spray today. Then doing the ceramic coating. I just found out the bilge pump is not on auto all the time, that seems really dumb. Shouldn’t it be on a hot battery buss?
