Remediation
Our warning sticker states to not use the front fishing seats while underway. These are full reclining helms seats inside the fence. CYA warning stickers all over the boat.
Isnt that the truth, stickers everywhere.Our warning sticker states to not use the front fishing seats while underway. These are full reclining helms seats inside the fence. CYA warning stickers all over the boat.
I have a 2017 24’ SSBXP with the electric bimini. I know mine has a max speed “sticker” or “print” somewhere on it. I LOVE having the elecitric bimini. However, I find that the electric bimini seems much more “fragile” when under any sort of speed as compared to a normal bimini that has better bracing/support. We don’t keep our bimini up if we are going anything above about 25-30 mph for that reason.I have the electric / automatic bimini top. I bought my boat used and I don't see anywhere on the boat or bimini top, a max speed sticker. Does anyone here know what the official response is from Bennington for the electric bimini top on my 23 SSBXP? I don't mean to thread hijack here, but I think others might find it useful too.
We have been up to 40 with our double Bimini up last summer. It's not like we cruise around like that all the time. We test drove a boat a few years ago that had a 350 Mercury Verado on the back and an open electric Bimini. The salesman was cruising along about 40mph when he looks over at my wife and I and says, hold on! He hit the throttle and the digital speedometer read 50-51. We asked about the stability of the electric Bimini because they don't have the supports like a regular Bimini top has and he said they are well built and can withstand higher speeds. I wouldn't have believed it if I didn't experience it firsthand......
My wife and I were looking at each other wondering if it was going to blow off but it didn't. It actually held up pretty good. This one didn't even have any support straps. Personally I wouldn't have done it but I guess he was trying to impress us......That dealer is soooo wrong - I have that setup and there's no way I'd run an open electric bimini top past 30 - even with the support straps on (which I always use when it's up/open and I'm moving past trolling speeds).
When I'm making speed runs I put the bimini into trailer position and use the metal stands. I've run it at 50+ with the top up and it bounces around pretty dramatically.
Is that with the standard non electric Bimini, no special support pins in?41 with my main one. i dont go that fast with the front one open
The original Double Biminis on my 22SSX were posted “Max 15 MPH”. However I replaced both tops under warranty and now both state ”30 MPH Max Wind Speed”. INTERESTING!The problem is, Bimini's can act like air foils. That is, depending on each individual design, length, width, curvature, and more, they can have an affect on how the boat performs. When that happens, there can and often is, some serious strain on bimini mounting points. Some can push down on those mount points and some will potentially LIFT on those mount points. Our boat is easily capable of 50 mph with its 350HP Yamaha. But, the double bimini that came with it, has a tag right near the center top bar that states, the speed with the Bimini's up should NOT EXCEED 15 MPH!
One thing about the front biminis is that the forward support arm black plastic foot that latches starts to wear with use and can pop loose if you don't have a pin on a lanyard to securely lock it in place. The wind is pushing against it with speed so vibration , wind, and wear could cause it to release at high speed. A safety pin lock would be wise to add just in case. Maybe forward straps also. Then it would be safe.
