Havasu
Mark,
I've put a bunch of car/boat stereos in so I'm pretty familiar with how to do it. I don't have the AS-10 (yet) but know a little about it. I had to look up your stereo deck and read through the manual. According to the specs, that deck puts out 4v (which is good). There is a subwoofer setting that you can adjust (output and LPF crossover settings). I'd look at that first. If you do end up adjusting it I'd suggest turning that AS-10 all the way down (both gain and remote) and start over with those settings. Double check your RCA cable to make sure you're on the sub out from the deck. Like Chris stated above, you want to use either the deck's crossover settings or the sub, not both. On the sub input (gain), you're trying to adjust the input to match the output of the deck. And, be careful with any bass boost as it can distort and muddy the sound. I typically run those all the way down (off). As for the antenna issue, I guess it could cause some sort of interference although I've never really seen that issue before. Rerouting it away from the sub should be an easy fix if that's the problem. My .02, hope it helps some. I'm sure Derrick will chime in here and sort it out as well.
