Power Bimini fail
OBrien673
My power arm Bimini stopped lifting today, did not break the circuit and didn’t reset after power turn off . What I can hear is a slight buzzing in the switch when we try it but no motors actuating at all up or down. Seems like maybe a simple switch fail. But not sure. Boat is three years old. Never had an issue till today. Thoughts are appreciated. We are stuck in a 3/4 open position.
Take it to your dealer . Thats covered under warranty
1. Warranty
2. See if this video helps you. I think it’s the same brand.
The gears stripped out on my actuators a couple weeks ago - waiting on replacements from Bennington. My dealer has been slow as molasses, but it's the end of the season. They're easy to remove and swap - takes about 15 minutes to remove both.
Your description sounds like a wiring issue though - if you can't hear the motors running the actuators aren't getting power. You can also test by removing one (or both) and using a test light at the connector.
Good luck!
The Bennington electric bimini is framed slightly differently than in the above video. Here’s what the Bennington one looks like.
Radar Position:
Stowed Down:
Deployed fully: (only 2 pictures I have of it deployed in 8 years of ownership. We don’t open it up very often, and apparently take pictures of it opened up even less).
Radar Position:
View attachment 36169View attachment 36171View attachment 36175View attachment 36176View attachment 36177
Stowed Down:
View attachment 36172View attachment 36173View attachment 36174
View attachment 36178View attachment 36179
Show off!
